Posted by bc on December 12, 2010 at 21:16:09 from (71.158.220.25):
In Reply to: Farmall H locked up! posted by Millercreek on December 12, 2010 at 18:52:47:
Good thing wind chill only applies to skin and not metal and oil. Changing hytran because of water to get the hydraulics to work I can see. But I'm not sure a little water in 80/90 wt. gear oil will make a difference in that stiff stuff even if it was milky and slimy feeling. I think you are just going to have to heat your oil and wait till the engine warms up.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
