Posted by Ken Christopherson on December 12, 2010 at 21:52:39 from (71.63.192.200):
In Reply to: Farmall H locked up! posted by Millercreek on December 12, 2010 at 18:52:47:
Just an FYI, on the 1940 M my uncle has, there was a bit of water in the rear end and it froze one MN winter back in say 1994/1995. The rear end did not lock up, but the ice chunk got lodged between the bull gear and the bottom of the housing and punched about a plum-sized hole in the casing. You would think the ice would have gave before the casing, but not the case, as we found the chunk of ice at the beginning of the trail of 80/90 weight. Might want to do your best to get the water out of there.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
