Re: Farmall H locked up!
Posted by glennster on December 13, 2010 at 07:37:10 from (76.222.60.13):
In Reply to: Farmall H locked up! posted by Millercreek on December 12, 2010 at 18:52:47:
like janicholson said, warm up the rear end and then loosen the drain plugs and let the water out till you get oil coming out. there may be sludge built up behind the drain plug, if so, poke it with a screwdriver to get the drain open. have 2 empty 5 gallon pails handy in case you drop the drain plug. when the water is out replace the drain plug. at this point i dump some kerosene in the the rear end and leave it. on an m, i use 2 gallons. an h would be a gallon and run the tractor for a week or so, then drain the oil and change it. the kerosene will thin the gear lube and loosen a lot of the crud.
