Re: '45 H Questions
Posted by LenND on December 13, 2010 at 17:59:59 from (74.207.160.118):
In Reply to: '45 H Questions posted by Hillbilly_H on December 13, 2010 at 15:51:09:
I don't think there is anything wrong with your cap. The dip stick is not meant to be solid. That cloth that you see is actually a small filter in the cap. There should be a little air hole somewhere in the cap or the threads so air gets in. It takes 6 quarts of hydraulic fluid of you choice to fill it.
