Quoting Removed, click Modern View to seeIn those graphs, 1 atmosphere is 14.7PSIA
150,000 feet = 2PSIA = 1.1 TORR = 0.043 inch Hg (near the valley of graph)
300,000 feet = 1.5PSIA = 0.00076 TORR = 0.00003 inch Hg (approx left side of graph)
Why would I use altitude? Because it gives meaning/relative feel to the Ivory soap crowd (the 99.44% of readers to which "Torr" has no meaning). If I had a chart with a different pressure scale, I would not have used this one.
It is more difficult, requires higher voltage, for ionizing arc to occur with higher pressures.
As for arc blow out.........high velocity air can be used to blow out an arc, but until the arc is established in the first place, there is no arc to blow out.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
