Re: (Jim) Firing Voltage versus Compression
Posted by greyfoxxca on December 14, 2010 at 07:19:08 from (137.186.159.24):
In Reply to: Re: (Jim) Firing Voltage versus Compression posted by JMOR on December 13, 2010 at 18:56:53:
Physical Conditions within the Spark Plug Gap affecting voltage needed for spark.
1. Gas pressure at the instant of ignition. This pressure is dependent upon ignition timing, engine load, compression ratio and engine RPM.
2. The gas velocity passing through the spark plug gap at the instant of ignition.
3. Engine fuel. The actual composition of the fuel being fed into the gap.
4. The temperature of the gas.
5. The fuel/ratio at the instant of ignition
lots of factors here with compression ratio just a small portion.
George
