Re:Washer and Bolt replies. Farmall 460 Diesel Gears not mes
Posted by Tod Michigan on December 14, 2010 at 15:04:21 from (69.97.231.84):
In Reply to: Re: Farmall 460, gears not meshing right posted by D Slater on December 13, 2010 at 11:24:08:
Thank you to everyone who took the time to post a reply and make suggestions, I really appreciate that you are trying to help.
I wanted to clear up this issue with respect to the bolt and specifically the washer that holds the gear on the end of that shaft. The washer and bolt are indeed tight and in place. I actually had lots of trouble with it this summer. The washer is actually a thick washer(about 1/8 to 3/16 thick) and is recessed(about 1/16") so it can go over the shaft slightly and the shoulder then keeps the gear tighter onto the splined shaft. I have fixed this issue early this summer and believe it is not the cause of the current issue. I have pulled the inspection plug and made sure the bolt is still tight, and also removed the pump mounting plate so I can visually see that everything is ok in this area and this is how I noticed that the Large gear that drives the hydraulic pump and the small gear above it are not aligned.
So I dont confuse things I will leave it at that. This post was in response of the replies about the washer and bolt issue.
Thanks again everyone for all your help.
Tod Michigan
