Understood you said bolt was tight in my post to you. One to OWEN A. was just to see if there was something I didn't know about the gear retaining changes. Putting a picture of shaft. Splined end is the gear mount. Race for the needle bearing is next. Needle bearing is pictured beside the shaft. Next ball bearing at rear and splined coupling that joins shaft to the next one at rear. Snap ring in the picture holds the rear ball bearing OD from moving to the rear. center housing is machined to keep it from going forward. Shaft is machined for the rear bearing ID. That along with the coupling pined to shaft keeps the bearing in place on shaft. That ball bearing handles the forward and rearward thrust of the shaft. Shaft is free to move forward and back in the needle bearing. If for some reason shaft moves to the rear enough for the drive gear to contact the needle bearing assembly it won't do it any good. If the shaft indeed has moved to the rear, thats why I suspect the ball bearing or retaining ring. Also may want to make sure the pto gear is not installed backwords on the shaft. Don't know if it would clear the housing though, never tried one backwards. Check that the top shaft has not moved forward. If it did though, most likley oil would be leaking out of the clutch compartment when running.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
