Need 400 help won't start in cold weather
Posted by Denis in MI on December 15, 2010 at 06:25:08 from (98.250.249.49):
I have a 400 gas that gives me trouble with starting every year when the mercury drops to below about 40 or 50 degreea. If you open the throttle and turn the key it just turns over and refuses to fire, If you open the throttle all the way it still will not fire, then if you back the throttle all the way down to the low idle stop it will fire a couple times and may keep running but as soon as you open the throttle it dies. If you play with it long enough you can get it to stay running and it runs exactly as it should and does during warmer weather. I was hoping to push some snow with it this year since I have no room in the barn for it this year. The tractor is 12 volt and cranks at a good speed but will not fire.
Thanks for any help or opinions,
Denis
