Re: Need 400 help won't start in cold weather
Posted by El Toro on December 15, 2010 at 09:36:46 from (108.3.200.96):
In Reply to: Need 400 help won't start in cold weather posted by Denis in MI on December 15, 2010 at 06:25:08:
If you still have a 6 volt coil and are using a ballast resistor between your ignition switch and coil you're dropping the battery voltage too much. Hal
