Re: 450 steering problem
Posted by Owen Aaland on December 18, 2010 at 15:44:12 from (198.70.47.181):
In Reply to: 450 steering problem posted by 756puller on December 18, 2010 at 13:08:48:
By cutting into the pressure line from the pump without using the 450 power steering valve you no longer have any pressure relief valve in the steering system. When the pressure builds up under load the weakest point will fail. It sounds like you found the weakest point.
