Re: Intl 434 424 / Clutch Pedal Adjustment
Posted by Troy Schubert on December 18, 2010 at 19:30:40 from (76.127.220.198):
In Reply to: Intl 434 424 / Clutch Pedal Adjustment posted by Troy Schubert on December 17, 2010 at 19:59:58:
I had success deburring the shaft with a file and roughing it up with 80 grit. Then I got brand new 3/8-24 grade 8 bolts, nuts, washers and tightened it down good. Problem solved.
My problem was the free play was 2", so the pedal was bottoming out before the 2nd stage PTO clutch would disengage.
Today's Featured Article - Memories of a Field Service Engineer - by Brian Dye. I worked for one of the largest Ford tractor dealerships in England as a trouble-shooter on tractor engines, hydraulics and combine harvesters from 1963 to 1972. In 1972 I became a dealer manager and finally left the dealer net in 1975 to run my own electronic design and manufacturing company called BHE after the old 16th century Inn where we are now based. We specialize in agricultural electronics working in the past for Claas, Grimme, Standens and Reekie on combines, potato and sugar beet har ... [Read Article]
