Intl 434 424 / Clutch Pedal Adjustment
Posted by Troy Schubert on December 17, 2010 at 19:59:58 from (76.127.220.198):
Reading manual and noting that it calls for 3/4" play at the top before engagement of clutch on 2 stage option. Mine is currently at 2" and PTO clutch will not disengage. Tonight, set it at 3/4", socked down the nuts/bolts til veins popped out on my forehead, then pressed down on clutch pedal. 3rd or 4th press, I could feel the pedal slip on the shaft and play went back to 2".
Now I have the pedal off, deburring shaft and hole of pedal and will try again.
Anyone have this issue? If this doesn"t work, I might drill and pin it? then I won"t have adjustment. Seems like a "not good" clutch adjustment design. Loctite?
