Re: M belts
Posted by RB on July 04, 2000 at 06:40:02 from (63.27.122.86):
In Reply to: M belts posted by Pete on July 04, 2000 at 06:29:57:
It is screwed on.There should be a locking screw on there to keep it tight.You will have to turn the engine over several times then screw it in some more and continue to do that until the belt is tight.Then simply turn in the locking screw.I think,and somebody correct me if Im wrong but there are flat spots on the threaded part that the set screw has to go on.
Post A Followup
: Re: Re: M belts
