Re: Re: M belts
Posted by The Red. Correct on July 04, 2000 at 06:42:29 from (12.75.197.222):
In Reply to: Re: M belts posted by RB on July 04, 2000 at 06:40:02:
There are 4 flat spots 90 degrees apart. That is where the set screw should be tightened once the flange is tightened to the desired tension.
Post A Followup
: Re: Re: Re: M belts
