Re: Farmall H 12 volt lights
Posted by loko17 on December 22, 2010 at 08:18:33 from (204.111.106.93):
In Reply to: Farmall H 12 volt lights posted by Yooper Farmall on December 22, 2010 at 06:57:00:
I bought a Super H that had been converted over from a 6 volt to a 12 volt system and the lights had all been burned out. I got replacement bulbs (sealed beams) from OEM Tractor Parts. As I recall, they were about $35.00 each. My light bar is on the column. If you do use the sealed beams I mentioned, be sure you that you get them hooked up correctly. (Positive and ground). If not, they will burn out. LOL.
