Re: SMTA FRONT TIEDOWN FOR HAULING
Posted by Janicholson on December 26, 2010 at 09:23:50 from (199.17.6.126):
In Reply to: Re: SMTA FRONT TIEDOWN FOR HAULING posted by S2710 on December 26, 2010 at 08:30:08:
With respect, I have two reservations about the process you are using.
I would rather have the load close to the frame rail, not out on the end of a nut. A bolted on plate with grab hook welded on is better.
The force that allows you to squish the tires is subtracted from the actual holding power.
A chain or fastner perloaded to 50% has only 50% left to hold the forces applied! Just squish enough to show some added tire deflection is better.
Respectfully Jim
