Posted by Ed Hotaling on December 26, 2010 at 17:06:54 from (69.204.170.52):
In Reply to: Time for a new project posted by Zachary Hoyt on December 26, 2010 at 16:31:49:
That looks like the #31 I have on my H. I have lifted about a ton with mine, but it gets a little hairy. It will stop lifting just before the rear tires come off the ground. As far as removal, yes you can drive right into it. You need to take the muffler off. I use a couple of large chunks of wood to rest mine on, undo the bolts and back away, no other machine needed, It takes about 15-20 minutes. If you plan to use it in cold weather, I would really recommend cleaning out the hydraulic system, checking for leaks and switching from 30 wt oil to Hytran or something similar (I use Ford hyd. fluid in mine because that's what my other tractor takes) I have 1 set of wheel weights and no fluid in the tires. If I could find another set of weights, I would put them on. It will rob you of traction. With a little practice, you can do anything with this loader that you can do with a modern one. Some things it will even do faster. I just looked back at the photo and can see that the loader needs some repairs. If you need help with that, shoot me an e-mail.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
