Gas tank
Posted by Michael D on December 27, 2010 at 12:12:28 from (24.223.200.215):
How can I clean the inside of my tank. The inside look's like when you take a propane torch to painted wood siding. I don't know what it is. Years of varnish, An attempt at a liner, not sure! I found a place on the internet that I could send it to that will sand blast and coat the inside with an epoxy, but I am not sure I want to do that. Thank's.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
