Posted by wayne in mn on December 27, 2010 at 12:43:32 from (66.228.242.147):
In Reply to: Gas tank posted by Michael D on December 27, 2010 at 12:12:28:
Muratic acid. Do a search for tips from others. The acid (diluted) will clean to bare metal; have hot water available to rinse and air pressure to blow dry. Plug the outlet and add fuel oil or diesel fuel and slosh around to coat the interior for rust prevention. (rusting will occur rapidly) The residue is nasty so have a plan for disposal of the dirty liquid.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
