Re: Using an H with a three point hitch and a loader
Posted by holmesw on December 28, 2010 at 08:04:56 from (12.213.112.37):
In Reply to: Re: Using an H with a three point hitch and a loader posted by Zachary Hoyt on December 28, 2010 at 07:20:18:
I believe that they are one way cylinders on the loader, and the pump I believe is a belly pump, since it is operated when the clutch is engaged.
