I would think you could put a shutoff right at the belly pump for the lines that go to the loader. Some people use one port for each cylinder in which case you'd need two shutoffs, others use a T and then you could just use one. If the cylinders are one way and only connected to the pump at the bottom of the cylinder then when the valves are closed the oil in the cylinders will stay in them and the control rod will be only controlling the 3 point hitch. If you have independent spool valves for the different functions it would be more complicated, but if you are controlling everything off the rod that angles down on the right hand side of the tractor I think this should do what you want done. Zach
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
