Re: ATF and Hy-Tran mix.
Posted by CJ Johnson on December 29, 2010 at 09:25:59 from (174.253.152.238):
In Reply to: Re: ATF and Hy-Tran mix. posted by IaGary on December 29, 2010 at 04:52:14:
Where in my post did I mention I was concerned about the ATF causing damage? I am concerned about compatibility issues with the ATF and Hy-Tran mixing together. I think I made that clear. It would literally be impossible to get the last half gallon or so of ATF out of the entire system and this is why I ask.
