Re: ATF and Hy-Tran mix.
Posted by IaGary on December 29, 2010 at 12:23:50 from (69.63.16.90):
In Reply to: Re: ATF and Hy-Tran mix. posted by CJ Johnson on December 29, 2010 at 09:25:59:
I guess I should have left the word hurting out and said why drain any of it unless your going to drain it all.
Kinda like pulling 2 quarts of oil out of the engine and putting two new quarts in.
