Re: MD sleeves
Posted by Andrew Z on January 01, 2011 at 15:34:14 from (64.252.112.28):
In Reply to: MD sleeves posted by sven on January 01, 2011 at 15:29:33:
They are supposed to be up a few thousadths. Either the rings became stuck or you have valve issues. Check to see if they are stuck to the piston and check the end gap of the ring in the cylinder and see what you get. Also a I/T manual would be of some help as well.
Andrew
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
