MD sleeves
Posted by sven on January 01, 2011 at 15:29:33 from (216.193.143.21):
I have an MD that has poor compression. I took the head off today and it found the engine has very few hours on it since it was rebuilt last. The sleeves have no lip and everything looks new. I noticed that both the block and the head appear to have been milled. The sleeves stick up above the surface of the block by a few thousands of an inch. I assume they should be flush with the block and only stick up because the block was milled. Is this going to cause problems if i put it back together the way it is. Any ideas why all the clyinders would have low compression even though the rebuilt engine does not have much time on it.
Thanks
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
