Posted by rustred on January 01, 2011 at 16:26:28 from (74.200.18.155):
In Reply to: MD sleeves posted by sven on January 01, 2011 at 15:29:33:
would be nice to post the compression results so we have something to go by. a real quick test on the small gas valves is to just remove the spark plugs when its running on diesel and see if there's a diesel compression leak . the starting valve mechanism needs to be adjusted correctly also.need .060-.080 clearance between starting valve and cam. lots of other things to check before pulling it apart. did the tractor get worked under load after o/h to seat the rings?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
