Re: MD sleeves
Posted by rustred on January 01, 2011 at 16:53:49 from (74.200.18.155):
In Reply to: MD sleeves posted by sven on January 01, 2011 at 15:29:33:
just thought of another important thing, did you check the valve lash gap? should be 0.017 hot. very easy to mess this up when not experienced for the job at hand. now that the head is off best to remove valves and look to see if they were seating good.when you checked compression at injectors was it set on deisel? you may also have problems in the fuel injection system, example injectors.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
