Re: MD sleeves
Posted by Janicholson on January 02, 2011 at 09:06:34 from (67.72.98.45):
In Reply to: MD sleeves posted by sven on January 01, 2011 at 15:29:33:
The valve job may have an effect if the seats were ground down into the head, and the old valves are reused (thin margins), the total compression can be dramatically reduced. Poor injector break pressure, pattern, or Prechamber installation all have starting and warm up issues that are far more probable than the poor compression you mention. I also do not believe it would run with compression that low.
Another issue is if it is running on all cylinders when running on gas. if it is not, or you are pulling it to start it, it is not broken, it just needs the 2 minutes of gasoline running on all cylinders, or 3to5 minutes when colder than 30 degrees. Jim
