Re: Farmall C or Super A Hydraulic Pump Rebuild
Posted by Ron-MO on January 03, 2011 at 08:09:57 from (173.186.165.216):
In Reply to: Farmall C or Super A Hydraulic Pump Rebuild posted by ihtrucker on January 03, 2011 at 06:37:24:
Likely leaking at the oring or seal where pump attaches to engine. I would remove the pump, then find out what you need. My C had a oring leaking (old and worn). I had a hard time locating an oring that was correct size. It seemed to be an odd ball size, but finally located at an older dealer. He had to go through some serious checking to figure out correct part number. Maybe you will be lucky, and it will be the common seal that is easy to get. They used two different pumps....I believe Pesco, and Thompson if memory serves correctly. Cannot recall which I had. The good news is that it lasted 60 years so I doubt I will have to do it again
