Farmall C or Super A Hydraulic Pump Rebuild
Posted by ihtrucker on January 03, 2011 at 06:37:24 from (216.226.179.180):
I have a tractor that was made up of a Farmall A & and Farmall C tractor to create a Farmall Super A. I am sure this has been commonly done before to allow someone to have a "Super A" with hydraulics. The hydraulics work when fluid is poured into the resivior, but I have noticed that the next time I go out to it, the fluid is gone. I am thinking that its getting into the engine crankcase somehow, as I drained the engine oil and almost 2 gallons of oil came out. Also, there is a SMALL drip on the hydraulic lines where the flange bolts to the pump. Not a drip from the flange, but where the line connects to the flange. Not a bad drip, and I can't see any bad places on the line.
What all do I need to do to fix the problem?? Hydraulic Pump Rebuild?, or simple Gaskets & O-Rings?? THANKS FOR ALL THE HELP.
