Re: Farmall C or Super A Hydraulic Pump Rebuild
Posted by redFarmallboy on January 03, 2011 at 09:41:00 from (75.40.243.113):
In Reply to: Farmall C or Super A Hydraulic Pump Rebuild posted by ihtrucker on January 03, 2011 at 06:37:24:
Does this look like what you have? I agree with some of the other posts. The seal on the pump is known for going bad and allowing hydro oil to leak into the motor. I would pull the pump and replace the seal and maybe use a thicker oil in the hydraulics. (I have a little bit different pump on my A as you can see because it is belt driven and sits up under the hood. (I also have a C so I know about the pump leaking into the motor).[/img]
