The input shaft on the pump can have two types of seals one has an o-ring the other type has a seal. If the housing wont clear the shaft after the speedy seal a letterd drill will enlarge but you want to mike the od before drilling. A machine shop should be able to do it. Just make sure the washer gets bent when replacing the gear so it wont come loose and wear out the hole in the gear. There are o-rings where the manifold bolts to the pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
