The diode will work and is what most use, I have used a small relay from radio shack energized by the ignition switch and have also used a oil pressure switch that is normally open to disconnect the alternator when the oil pressure gets down to 4 or 5 psi. This switch is also used to turn off the hour meter if the trractor is not running and the switch is left on. The diode is by far the easiest to install.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
