Posted by Yooper Farmall on January 04, 2011 at 12:17:14 from (141.210.112.16):
I've bolted up a new Hitachi 12 volt alternator to a 1941 H using an aftermarket alternator bracet that I already had. I have a wiring question:
currently, applying 12 volts to the "S" terminal does not excite the field and cause the alternator to start chargine. However applying 12 volts to teh "L" terminal does. The problem is that if the voltage is applied to "L" at all times, there is a constant draw. If a switch is introduced in the circuit to the "L" termnial, it back feeds the coil and the tractor will not shut off. What is the fix to this? I see Dean has wired up a diod of some sort on his 300 Farmall. I'd prefer not to have to add a charging toggle switch on the light bar.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
