Re: Connecting a Hitachi #14231 12volt to a Farmall H
Posted by Janicholson on January 04, 2011 at 13:26:27 from (199.17.6.126):
In Reply to: Connecting a Hitachi #14231 12volt to a Farmall H posted by Yooper Farmall on January 04, 2011 at 12:17:14:
The diode is workable, the use of a resistor (10 to 20 ohm at 10 watts) or a parking light bulb (not LED type) wioll also work.
The diode should be placed with the banded end toward the alternator.
The S terminal should be connected to the Bat (large output) terminal with a short #12 wire.
I recommend putting a 40 amp fuse link in the wire going from the alternator to the amp meter. This prevents electrical fires if things go wrong, or a battery is hooked up backwards. Jim
