Springs and specialty fasteners are in almost every case special. Thus a replacement is going to be an approximation of the real thing. Springs are rated in terms of rate, and physical size. This includes wire size, pitch (variable or fixed) coil diameter, end configuration, compression, or tension, material, and heat treatment, flat wound and ground, and other designations. These are not available outside of the engineering prints, and would not be duplicable in 90% of the cases unless the spring was very valuable and not available OEM, or NOS, or used. Many bolts and nuts are also in this category. Head configuration plating, shank diameter, thread length and class of thread fit, are all proprietary. Many common bolts are usable in replacement, but the Correct Police can detect them from 4 yards away. I have no issue using screen door springs for clutch/brake return, but that is me. I did not answer the question with sourcing, because there are none other than those we know. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
