Specifications on Hardware Parts for tractors...HELP
Posted by rtr on January 04, 2011 at 11:53:34 from (216.226.179.180):
Would anyone happen to know where I can get certain specifications on parts for a Super A-140 tractor as well as the Cub tractors?? I use the CASE/IH website to locate parts when I am putting tractors back together, however if I want to purchase common parts (bolts, springs, etc); the parts breakdown doesn't list the specs on all of them. With brake return springs at $10.00 on Ebay; it would get a little costly when I ordered 40 springs. Same with the other hardware. I always order that stuff from the local hardware supply store, when I know original specs.
For now, I am wanting to order the brake and clutch pedal return springs (the CORRECT ones), and would like to know the specs, and how to identify the correct spring (spring terminology & specs) so I can purchase them bulk at a general "spring distributor". THANKS GUYS
