Re: B Farmall Block Hole
Posted by Heat Houser on January 06, 2011 at 09:41:15 from (69.66.35.73):
In Reply to: Re: B Farmall Block Hole posted by Janicholson on January 06, 2011 at 07:23:47:
Yep, plan on giving it a good cleaning and sandblasting in the suspect areas. Don't need to repair one area and then find another.
Reading up on brazing cast, they recommend using a carbide cutter instead of a grinder. A grinder embeds carbon in the area which will not allow a good bond. They also said to have the block up to a temp that will melt the brazing rod without being in the flame.
Anybody used Muggy Weld products?
