Re: B Farmall Block Hole
Posted by Janicholson on January 06, 2011 at 07:23:47 from (199.17.6.126):
In Reply to: B Farmall Block Hole posted by Heat Houser on January 05, 2011 at 18:57:08:
That is what I would do. I would heat the whole block to at least 150 degrees before brazing to keep temperature shock to a minimum. If it is thin there, baybe a sand blasting of other potential leak areas would assure a good repair, and confidence. Jim
