Re: farmall240
Posted by redFarmallboy on January 06, 2011 at 10:08:50 from (75.40.243.113):
In Reply to: farmall240 posted by Ron McQuigg on January 05, 2011 at 16:03:54:
can't you just pull the throttle lever off the shaft and pull the dash out (once the steering wheel is removed of course)?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
