Re: farmall240
Posted by Ron McQuigg on January 07, 2011 at 12:23:28 from (98.166.117.3):
In Reply to: Re: farmall240 posted by redFarmallboy on January 06, 2011 at 10:08:50:
Thanks for the response but the throttle handle will not come off. I removed the nut and put on a wheel puller and nothing moved. I wish it could have been simple.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
