Re: Farmall A. Help, I've got an oil leak!
Posted by Bill in NJ on January 06, 2011 at 16:10:40 from (209.86.226.27):
In Reply to: Farmall A. Help, I've got an oil leak! posted by Enar on January 06, 2011 at 15:52:20:
Hopefully as part of the restoration you cleaned the outside of the engine completely. That being the case you should be able to trace the source of the leak. You might need a flashlight and mirror on an extention wand. Not really that many places an oil leak can hide on that engine.
