Re: B Farmall Block Hole
Posted by sflem849 on January 06, 2011 at 16:46:17 from (69.197.84.192):
In Reply to: B Farmall Block Hole posted by Heat Houser on January 05, 2011 at 18:57:08:
Rumor has it that it doesn't take much to stop a leak in an A/B bc it isn't a pressurized system. If you can get a welding rod in there you can just arc weld it. There is a lot better technology out there now days. Brazing worked well, but the new Supermissle rods, etc are awesome.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
