B Farmall Block Hole
Posted by Heat Houser on January 05, 2011 at 18:57:08 from (69.66.35.73):
What do you use to plug a hole in a block?
Pulled the sleeves on the B Farmall and was scratching around in the water jacket area getting rust and scale out. Up near the front by the camshaft bore, it was very thin and I poked thru. I now have a small hole between the water jacket and the crankcase.
I was thinking about sand blasting the area to get to bare cast iron and then brasing it shut. Anybody had good luck doing this kind of repair?
Thanks
