Re: Brakes !!!! Won't Shift???
Posted by sflem849 on January 07, 2011 at 09:05:53 from (69.197.84.192):
In Reply to: Brakes !!!! Won't Shift??? posted by Farmall Dann on January 06, 2011 at 21:54:18:
For my reference
Just scuff the friction material???
How do you usually polish the balls and ramps?
Spray all parts with brake cleaner and that is good? (unless you see more problems than that can handle?)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
