Re: Brakes !!!! Won't Shift???
Posted by Janicholson on January 07, 2011 at 09:22:12 from (199.17.6.126):
In Reply to: Re: Brakes !!!! Won't Shift??? posted by sflem849 on January 07, 2011 at 09:05:53:
I use a dowel with a piece of 250 grit paper wrapped on it to polish the ramps, and a wire wheel to polish/clean the balls. wear pits in the ramps are very important to remove. If deeper than .005" I would replace the expander. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
