We can do this together John!! I resist accepting the idea that the repair can be ignored, connecting to the Bat terminal. If the heavy winding is not wrapped around the relay core (effectively because it is broken in the middle) the current regulation function of the regulator will be gone. The voltage component may work, but then again it may be balanced against the current winding and it could just not regulate well at all.
I have been looking at the diagram provided in the post below.
I feel that it would be necessary to have that path of current flow. I also believe solder would need to be silver solder based to conduct enough and be strong enough to be reliable. A tough repair.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
