Tell ya what Id do, it dont work as is so no harm in trying to patch her up cuz at worse it still wont work lol
That circuit from L to BAT simply winds around that one relay, so as long as its spliced AND NOT SHORTED TO CASE/FRAME heck it may work.
GO FOR IT
HOWEVER if youre not a risk taker you can still use the VR AS IS JUST IGNORE THE L TERMONAL. Simply remove the feed wire off L and hook it instead to EITHER the Load (NOT battery) side of the ammeter or else just over to BAT on the VR. Again, all it does is feed hopt batetry voltage to loads like lights and ignition.
I guess if the patch job looks too risky or theres a chance that wire may short to case, just go the ignore L route and re feed as noted above.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
