Re: Voltage Regulator repair
Posted by John T on January 08, 2011 at 12:11:29 from (66.87.0.12):
In Reply to: Re: Voltage Regulator repair posted by Dave H (MI) on January 08, 2011 at 07:22:39:
I just cant say where that dern short is from sittin here either, maybe it melted its way clear??? Again, so long as the wire leads from BAT to LOAD (as the picture diagram indicates) via those turns around the relays iron pole AND IS NOTTTTTTTTT SHORTED it ought to work. The 4 pole VR helps prevent overcharging by only sending enough current to the battery as necessary while allowign genny current to feed loads directly without having to pass thru the cutout relay.
WE cant help much more not being there and it sounds like you know how n what youre doin so press on I say n good luck..
John T
